- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 2 $
- * $Date: 16/10/25 4:30p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Show how to use timer0 to create various delay time.
- * @note
- * Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC029xGE.h"
- #define PLL_CLOCK 72000000
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable HIRC clock */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Waiting for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Switch HCLK clock source to HIRC */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Enable HXT */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
- CLK_SetCoreClock(PLL_CLOCK);
- CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
- /* Enable peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(TMR0_MODULE);
- CLK_EnableModuleClock(TMR1_MODULE);
- /* Peripheral clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_PLL, CLK_CLKDIV0_UART(1));
- CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_PCLK0, 0);
- CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0);
- /* Init I/O Multi-function */
- /* Set multi-function pins for UART0 RXD and TXD */
- SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
- SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
- void UART0_Init(void)
- /* Init UART */
- /* Reset UART module */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* MAIN function */
- int main(void)
- volatile uint32_t u32DelayTime;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
- printf("+-----------------------------------+\n");
- printf("| Timer Delay API Sample Code |\n");
- printf("+-----------------------------------+\n\n");
- printf("# This sample code is using Timer1 to check Timer0 TIMER_Delay API delay time is reasonable or not.\n");
- printf("# Delay time includes 100 ms, 200 ms, 300 ms, 400 ms and 500 ms.\n\n");
- /* Start Timer1 to measure delay period of TIMER_Delay API is reasonable or not */
- TIMER1->CTL = TIMER_PERIODIC_MODE | (12 - 1);
- TIMER_ResetCounter(TIMER1);
- TIMER_Start(TIMER1);
- TIMER_Delay(TIMER0, 100000);
- u32DelayTime = TIMER_GetCounter(TIMER1) / 1000;
- printf(" Check DelayTime-1 is %d ms .... ", u32DelayTime);
- if(u32DelayTime == 100)
- printf("PASS.\n");
- else
- printf("FAIL.\n");
- TIMER_Delay(TIMER0, 200000);
- printf(" Check DelayTime-2 is %d ms .... ", u32DelayTime);
- if(u32DelayTime == 200)
- else
- TIMER_Delay(TIMER0, 300000);
- printf(" Check DelayTime-3 is %d ms .... ", u32DelayTime);
- if(u32DelayTime == 300)
- else
- TIMER_Delay(TIMER0, 400000);
- printf(" Check DelayTime-4 is %d ms .... ", u32DelayTime);
- if(u32DelayTime == 400)
- else
- TIMER_Delay(TIMER0, 500000);
- printf(" Check DelayTime-5 is %d ms .... ", u32DelayTime);
- if(u32DelayTime == 500)
- else
- printf("\n*** Check TIMER_Delay API delay time done ***\n");
- while(1);
- /*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
