华大单片机HC32L130/HC32L136从机IIC通信
选用中断方式进行:
- uint8_t u8Recdata1[10] = {0x00};
- uint8_t u8Recdata[10]={0x00};
- uint8_t u8SendLen=0;
- uint8_t u8RecvLen=0;
- uint8_t u8RecvLen1=0;
- uint8_t u8State = 0;
- static void I2c0CallBack(void)
- u8State = I2C_GetState(I2C0);
- switch(u8State)
- case 0x60:
- case 0x70:
- case 0xa0:
- u8RecvLen = 0;
- I2C_SetFunc(I2C0,I2cAck_En);
- break;
- case 0x68:
- case 0x78:
- case 0x88:
- case 0x98:
- break;
- case 0x80:
- case 0x90:
- u8Recdata[u8RecvLen++] = I2C_ReadByte(I2C0);//接收数据
- break;
- case 0xa8://接收读命令返回ACK
- case 0xb0:
- u8SendLen = 0;
- I2C_WriteByte(I2C0,u8Recdata[u8SendLen++]);//发送数据首字节
- break;
- case 0xb8:
- break;
- case 0xc0:
- case 0xc8:
- break;
- I2C_ClearIrq(I2C0);
- void IIC_SlaveGpioConfig(void)
- stc_i2c_addr_t stcSlaveAddr;
- stc_gpio_config_t stcGpioCfg;
- stc_i2c_config_t stcI2cCfg;
- stc_sysctrl_clk_config_t stcCfg;
- DDL_ZERO_STRUCT(stcCfg);
- DDL_ZERO_STRUCT(stcI2cCfg);
- DDL_ZERO_STRUCT(stcGpioCfg);
- DDL_ZERO_STRUCT(stcSlaveAddr);
- Sysctrl_ClkSourceEnable(SysctrlClkRCL,TRUE);
- Sysctrl_SysClkSwitch(SysctrlClkRCL);
- Sysctrl_SetRCHTrim(SysctrlRchFreq24MHz);
- Sysctrl_SysClkSwitch(SysctrlClkRCH);
- Sysctrl_ClkSourceEnable(SysctrlClkRCL,FALSE);
- Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);
- Sysctrl_SetPeripheralGate(SysctrlPeripheralI2c0,TRUE);
- stcGpioCfg.enDir = GpioDirOut;
- stcGpioCfg.enOD = GpioOdEnable;
- stcGpioCfg.enPuPd = GpioPu;
- Gpio_Init(GpioPortB, GpioPin8,&stcGpioCfg);//端口初始化
- Gpio_Init(GpioPortB, GpioPin9,&stcGpioCfg);
- Gpio_SetAfMode(GpioPortB, GpioPin8,GpioAf1);//SCL
- Gpio_SetAfMode(GpioPortB, GpioPin9,GpioAf1);//SDA
- stcI2cCfg.enFunc = I2cBaud_En;
- stcI2cCfg.u8Tm = 0x02;//1M=(24000000/(8*(2+1))//波特率配置
- stcI2cCfg.pfnI2c0Cb = I2c0CallBack;
- stcI2cCfg.bTouchNvic = TRUE;
- I2C_DeInit(I2C0);
- stcSlaveAddr.Addr = 0x12;
- stcSlaveAddr.Gc = 0;
- I2C_Init(I2C0,&stcI2cCfg);//模块初始化
- I2C_WriteSlaveAddr(I2C0,&stcSlaveAddr);//写从机设备地址
- I2C_SetFunc(I2C0,I2cMode_En);//模块使能
- I2C_SetFunc(I2C0,I2cAck_En);//ACK打开
- if(TRUE == stcI2cCfg.bTouchNvic)
- EnableNvic(I2C0_IRQn,IrqLevel3,TRUE);
- int32_t main(void)
- IIC_SlaveGpioConfig();
- while(1)
