stm32f051DMAADC采样第一次值总是不对
6489|5
 楼主| wago2008 发表于 2013-6-4 09:35 | 显示全部楼层 |阅读模式
用stm32f051做过无路DMAADC采样,都没有问题,这次想采集一路不进DMA中断,在TIM1中断中控制DMA,可是每次启动DMA得到的数组的第一个值总是错的,确实是采到了0xFFF和0x000,因为初始化数组每个元素都是1,也会出现那两个值,各位大侠给个方向。
  1. void ADC1_CH_DMA_Config(char collectroadnum)
  3.         ADC_InitTypeDef           ADC_InitStructure;
  4.         DMA_InitTypeDef          DMA_InitStructure;
  5.         NVIC_InitTypeDef         NVIC_InitStructure;
  6.         /* GPIOC Periph clock enable */
  7.         /* GPIOC 外设时钟使能 */
  8.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
  9.         /* ADC1 Periph clock enable */
  10.         /* ADC1 外设时钟使能 */
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  12.         /* DMA1 clock enable */
  13.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE);
  14.         /* Configures the ADC clock (ADCCLK) */
  15.         /* ADCs 默认值初始化 */
  16.         ADC_DeInit(ADC1);//选择频道
  17.         /* 复位HSI14位 */
  18.         RCC->CR2 &= (uint32_t)0xFFFFFFFE;
  19.         //一次时间=(41.5 + 12.5)ADC时钟周期
  20.         //1us 一次1.5+12.5
  21.         /* 配置ADC时钟(ADCCLK) *///采用自带的14MHZ
  22.         RCC_ADCCLKConfig(RCC_ADCCLK_HSI14);
  23.         /* 当ADC1时钟被PCLK以4分频时失能抖动(jitter) */
  24.         //ADC_JitterCmd(ADC1, ADC_JitterOff_PCLKDiv4, DISABLE);
  25.         /* Configure ADC Channel12 as analog input */
  26.          /* 配置ADC通道作为模拟输入 */
  27.         if(collectroadnum==1)
  28.                 {
  29.                         //collect 1 road
  30.                         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 ;
  31.                 }
  32.         else if(collectroadnum==2)
  33.                 {
  34.                         //collect 3 road
  35.                         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
  36.                 }
  37.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  38.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  39.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  40.         //初始 ADC 配置
  41.         ADC_StructInit(&ADC_InitStructure);
  42.         /* 配置ADC1为12位分辨率的连续模式 */
  43.         ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  44.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  45.         ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  46.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  47.         ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Upward;//ADC_ScanDirection_Backward,ADC_ScanDirection_Upward
  48.         ADC_Init(ADC1, &ADC_InitStructure);
  49.         //采样时间
  50.         if(collectroadnum==1)
  51.                 {
  52.                         // 用1.5个ADC时钟周期作为采样时间配置ADC1通道10
  53.                         ADC_ChannelConfig(ADC1, ADC_Channel_11 , ADC_SampleTime_1_5Cycles);
  54.                 }
  55.         else if(collectroadnum==2)
  56.                 {
  57.                         // 用41.5个ADC时钟周期作为采样时间配置ADC1通道10
  58.                         ADC_ChannelConfig(ADC1, ADC_Channel_12 , ADC_SampleTime_1_5Cycles);
  59.                         // 用41.5个ADC时钟周期作为采样时间配置ADC1通道11
  60.                         ADC_ChannelConfig(ADC1, ADC_Channel_13 , ADC_SampleTime_1_5Cycles);
  61.                 }
  62.         /* ADC 校准 */
  63.         ADC_GetCalibrationFactor(ADC1);
  64.         /* 使能ADC外设(PerIdx) */
  65.         ADC_Cmd(ADC1, ENABLE);
  66.         /* Wait the ADCEN falg */
  67.         /* 等待ADC结束标志 */
  68.         while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));
  69.         /* Enable ADC_DMA */
  70.         ADC_DMACmd(ADC1, ENABLE);
  71.         /* ADC1 regular Software Start Conv */
  72.         /* ADC1 定期软件启动转换 */
  73.         ADC_StartOfConversion(ADC1);
  74.         //DMA 配置
  75.         /* DMA1 Channel1 Config */
  76.         //选择通道
  77.           DMA_DeInit(DMA1_Channel1);
  78.         //设置外设地址
  79.           DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
  80.           DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  81.           //缓冲为(数组长度)
  82.           if(collectroadnum==1)
  83.                   {
  84.                           //设置内存映射地址
  85.                           DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&RegularConvData_Tab1;
  86.                           DMA_InitStructure.DMA_BufferSize =30;                          //开启通道数1 个
  87.                   }
  88.         else if(collectroadnum==2)
  89.                 {
  90.                         //设置内存映射地址
  91.                           DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&RegularConvData_Tab2;
  92.                         DMA_InitStructure.DMA_BufferSize = 2;                          //开启通道数2 个
  93.                 }
  94.         //关外设地址计数地址增量
  95.           DMA_InitStructure.DMA_PeripheralInc =DMA_PeripheralInc_Disable;
  96.         //内存地址计数
  97.           DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  98.           DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  99.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  100.         //循环模式
  101.           DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//单次写满20就停了
  102.         //高优先级
  103.           DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  104.         //关内存到内存
  105.           DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  106.         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  107.           DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);//DMA中断
  108.         //配置DMA循环模式
  109.         ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
  110.         //dma  DMA中断
  111.         // Enable the DMA Interrupt
  112.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
  113.         NVIC_InitStructure.NVIC_IRQChannelPriority = 0x01;
  114.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  115.         NVIC_Init(&NVIC_InitStructure);
  116.         DMA_ClearFlag(DMA1_FLAG_TC1);//清除DMA TC1标志
  117.         // DMA1 Channel1 enable
  118.           DMA_Cmd(DMA1_Channel1, ENABLE);
  119. }
IJK 发表于 2013-6-4 09:56 | 显示全部楼层
感觉应该需要注意一下 启动ADC和DMA的先后顺序
logokfu 发表于 2013-6-4 09:57 | 显示全部楼层
先设置好DMA然后再启动ADC试试
mgarm 发表于 2016-2-20 23:06 | 显示全部楼层
请问楼主:您的RCC->CR2 &= (uint32_t)0xFFFFFFFE;是关闭内部14M时钟吧,后来你也没有打开,那ADC是怎么工作的?
凯子 发表于 2016-8-13 19:48 | 显示全部楼层
楼主怎么解决的?
