| hnkf118 发表于 2014-12-25 23:07  那就还是自己动手搞一下吧。 具体有什么问题,再请教可能有人帮你回答问题,你这太。。。 ...
下面这段程序怎么修改呀,为什么在keil中显示错误?
 #include<reg51.h>
 #include "intrins.h"
 #define uchar unsigned char
 #define uint unsigned int
 uchar Vo;                //A/D转换后换算的电压值
 /*Declare SFR associated with the ADC */
 sfr ADC_CONTR   =   0xBC;           //ADC control register
 sfr ADC_RES     =   0xBD;           //ADC high 8-bit result register
 //sfr ADC_RESL    =   0xBE;
 sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
 sfr P1ASF       =   0x9D;           //P1 secondary function control register
 /*Define ADC operation const for ADC_CONTR*/
 #define ADC_POWER   0x80            //ADC power control bit
 #define ADC_FLAG    0x10            //ADC complete flag        模数转换结束标志位
 #define ADC_START   0x08            //ADC start control bit         模数转换                                             ///启动控制位
 //转换速度控制位SPEED0和SPEED1,共四种状态,对应四种转换速度
 #define ADC_SPEEDLL 0x00            //540 clocks
 #define ADC_SPEEDL  0x20            //360 clocks
 #define ADC_SPEEDH  0x40            //180 clocks
 #define ADC_SPEEDHH 0x60            //90 clocks
 uchar tCount;
 sbit RS=P3^7;    //寄存器选择位,将RS位定义为P3.7引脚
 sbit RW=P3^6;    //读写选择位,将RW位定义为P3.6引脚
 sbit EN=P2^7;     //使能信号位,将E位定义为P2.7引脚
 void DelayMS(uint ms)
 uint i;
 while(ms--)
 for(i=0;i<120;i++);
 Software delay function
 void Delay(uint n)
 uint x;
 while (n--)
 x = 5000;
 while (x--);
 Initial ADC sfr
 void InitADC()
 P1ASF = 0x01;                   //选择P1.0作为A/D输入通道
 ADC_RES = 0;                    //清0
 ADC_CONTR = ADC_POWER | ADC_SPEEDLL;   //0x10|0x00=0x10:开电源和设置A/D                                     //转换速度
 Delay(2);                       //ADC power-on and delay
 Get ADC result
 uchar GetADCResult(uchar ch)
 ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;//0x00|0x00|ch|0x08:选择A/D输入通道,开始A/D转换
 _nop_();         //Must wait before inquiry ,
 _nop_();        //设置ADC_CONTR寄存器后需加4个CPU时钟周期的延时,才能保证值被写入ADC_CONTR寄存器
 _nop_();
 _nop_();
 while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
 ADC_CONTR &= ~ADC_FLAG;         //Close ADC
 Vo=ADC_RES*5*10/256;                 //Return ADC result(为显示整数,这                                       //里将电压值扩大了十倍)
 return Vo;
 uchar Read_LCD_State()
 uchar state;
 RS=0;
 RW=1;
 EN=1;
 DelayMS(1);
 state=P2;
 EN = 0;
 DelayMS(1);
 return state;
 void LCD_Busy_Wait()
 while((Read_LCD_State()&0x80)==0x80);
 DelayMS(5);
 void Write_LCD_Data(uchar dat)     //写数据到1602
 LCD_Busy_Wait();
 RS=1;
 RW=0;
 EN=0;
 P2=dat;
 EN=1;
 DelayMS(5);
 EN=0;
 void Write_LCD_Command(uchar cmd)    //写命令
 LCD_Busy_Wait();
 RS=0;
 RW=0;
 EN=0;
 P2=cmd;
 EN=1;
 DelayMS(5);
 EN=0;
 void Init_LCD()     //1602  初始化
 Write_LCD_Command(0x38);
 DelayMS(5);
 Write_LCD_Command(0x01);          //清屏
 DelayMS(5);
 Write_LCD_Command(0x06);         //
 DelayMS(5);
 Write_LCD_Command(0x0c);
 DelayMS(5);
 void Set_LCD_POS(uchar p)
 Write_LCD_Command(p|0x80);
 void Display_LCD_String(uchar p,uchar *s) //1602显示
 uchar i;
 Set_LCD_POS(p);
 for(i=0;i<16;i++)
 Write_LCD_Data(s);
 DelayMS(5);
 void Format_DateTime(uchar d,uchar *a)
 a[0]=d/10+'0';
 a[1]=d%10+'0';
 //写入液晶第二行
 void display(uchar add,uchar date)
 uchar shi,ge;
 shi=date/10+'0';
 ge=date%10+'0';
 Write_LCD_Command(0x80+0x40+add);
 Write_LCD_Data(shi);
 Write_LCD_Data(ge);
 //写入液晶第一行
 void display1(uchar add,uchar date)
 uchar shi,ge;
 shi=date/10;
 ge=date%10;
 Write_LCD_Command(0x80+add);
 Write_LCD_Data(0x30+shi);  //0x30即48(十进制)对应的ASCAII码为字符                                       //‘0’
 Write_LCD_Data(0x30+ge);
 void main()
 Init_LCD();
 InitADC();
 while (1)
 GetADCResult(0);
 Display_LCD_String(0,"dianya:");
 display1(7,Vo);
 Display_LCD_String(9,"V      ");
 DelayMS(1000);
