stm32f407的usart2之dma发送和接收,采用空闲中断。
1748|0
 楼主| keer_zu 发表于 2022-1-6 07:51 | 显示全部楼层 |阅读模式
采用dma的usart2
  1. static char usart2_dma_tx[256];
  2. unsigned char usart2_tx_busy_flag = 0;
  3. static char usart2_dma_rx[1024];
  4. unsigned char usart2_rx_busy_flag = 0;
  5. static void usart2_gpio_init(void)
  6. {
  7.         GPIO_InitTypeDef GPIO_InitStructure;
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE);
  9.
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  11.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  12.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;
  15.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  16.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_USART2);
  17.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_USART2);
  18. }
  19. static void usart2_usart_init(unsigned int bauderate, unsigned short wordLength, unsigned short stopBits, unsigned short Parity)
  20. {
  21.         USART_InitTypeDef USART_InitStructure;
  22.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
  23.
  24.         USART_InitStructure.USART_BaudRate = bauderate;
  25.         USART_InitStructure.USART_WordLength = wordLength;
  26.         USART_InitStructure.USART_StopBits = stopBits;
  27.         USART_InitStructure.USART_Parity = Parity;
  28.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  29.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  30.         USART_Init(USART2, &USART_InitStructure);
  31.         USART_Cmd(USART2, ENABLE);
  32.         USART_DMACmd(USART2,USART_DMAReq_Rx,ENABLE);
  33.         //USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  34.         USART_ITConfig(USART2,USART_IT_RXNE,DISABLE);
  35.         USART_ITConfig(USART2, USART_IT_IDLE, ENABLE);
  36. }
  37. static void uart2_dmarx_config(uint8_t *mem_addr, uint32_t mem_size)
  38. {
  39.         DMA_InitTypeDef DMA_InitStructure;
  40.         //串口收DMA配置
  41.         //启动DMA时钟
  42.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  43.         //DMA通道配置
  44.         DMA_DeInit(DMA1_Stream5);
  45.         DMA_InitStructure.DMA_Channel = DMA_Channel_4;
  46.         //外设地址
  47.         DMA_InitStructure.DMA_PeripheralBaseAddr = (unsigned int)(&USART2->DR);
  48.         //内存地址
  49.         DMA_InitStructure.DMA_Memory0BaseAddr = (unsigned int)mem_addr;
  50.         //dma传输方向
  51.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  52.         //设置DMA在传输时缓冲区的长度
  53.         DMA_InitStructure.DMA_BufferSize = mem_size;
  54.         //设置DMA的外设递增模式,一个外设
  55.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  56.         //设置DMA的内存递增模式
  57.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  58.         //外设数据字长
  59.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  60.         //内存数据字长
  61.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  62.         //设置DMA的传输模式
  63.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  64.         //设置DMA的优先级别
  65.         DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  66.
  67.         //指定如果FIFO模式或直接模式将用于指定的流 : 不使能FIFO模式
  68.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  69.         //指定了FIFO阈值水平
  70.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  71.         //指定的Burst转移配置内存传输
  72.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  73.         //指定的Burst转移配置外围转移 */
  74.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  75.
  76.         //配置DMA1的通道
  77.         DMA_Init(DMA1_Stream5, &DMA_InitStructure);
  78.         //使能通道
  79.         DMA_Cmd(DMA1_Stream5,ENABLE);
  80.
  81.
  82.         USART_DMACmd(USART2,USART_DMAReq_Rx,ENABLE);
  83. }
  84. static void usart2_dma_init(void)
  85. {
  86.         DMA_InitTypeDef  DMA_InitStructure;
  87.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  88.
  89.         DMA_DeInit(DMA1_Stream6);
  90.         DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  91.         DMA_InitStructure.DMA_BufferSize = 256;
  92.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  93.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  94.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  95.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  96.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  97.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  98.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  99.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull;
  100.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  101.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  102.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&USART2->DR;
  103.         DMA_InitStructure.DMA_Channel = DMA_Channel_4;
  104.         DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)usart2_dma_tx;
  105.         DMA_Init(DMA1_Stream6, &DMA_InitStructure);
  106.         DMA_ITConfig(DMA1_Stream6, DMA_IT_TC, ENABLE);
  107.         uart2_dmarx_config(usart2_dma_rx,1024);
  108. }
  109. static void usart2_nvic_init(void)
  110. {
  111.         NVIC_InitTypeDef NVIC_InitStructure;
  112.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 5;
  113.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  114.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream6_IRQn;
  115.         NVIC_Init(&NVIC_InitStructure);
  116.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream5_IRQn;
  117.         NVIC_Init(&NVIC_InitStructure);
  118.         NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  119.         NVIC_Init(&NVIC_InitStructure);
  120. }
  121. void usart2_init(unsigned int bauderate, unsigned short wordLength, unsigned short stopBits, unsigned short Parity)
  122. {
  123.         usart2_nvic_init();
  124.         usart2_gpio_init();
  125.         usart2_usart_init(bauderate, wordLength, stopBits, Parity);
  126.         usart2_dma_init();
  127.
  128. }
  129. void usart2_send(char *buf, unsigned char len)
  130. {
  131.         while(usart2_tx_busy_flag)        delay_ms(2);
  132.         usart2_tx_busy_flag = 1;
  133.         printf("== dma tx\n");
  134.         memcpy(usart2_dma_tx, buf, len);
  135.         DMA_SetCurrDataCounter(DMA1_Stream6, len);
  136.         DMA_Cmd(DMA1_Stream6, ENABLE);
  137.         USART_DMACmd(USART2, USART_DMAReq_Tx, ENABLE);
  138. }
  139. /*****************USART2  TX******************/
  140. void DMA1_Stream6_IRQHandler(void)
  141. {
  142.         printf("== %d dma 1-6\n",__LINE__);
  143.         /* Test on DMA Stream Transfer Complete interrupt */
  144.         if (DMA_GetITStatus(DMA1_Stream6, DMA_IT_TCIF6))
  145.         {
  146.                 /* Clear DMA Stream Transfer Complete interrupt pending bit */
  147.                 DMA_ClearITPendingBit(DMA1_Stream6, DMA_IT_TCIF6);
  148.                 USART_DMACmd(USART2, USART_DMAReq_Tx, DISABLE);
  149.                 DMA_Cmd(DMA1_Stream6, DISABLE);
  150.                 usart2_tx_busy_flag = 0;
  151.         }
  152. }
  153. /*****************USART2  RX******************/
  154. void DMA1_Stream5_IRQHandler(void)
  155. {
  156.         printf("== %d dma rx\n",__LINE__);
  157.         /* Test on DMA Stream Transfer Complete interrupt */
  158.         if (DMA_GetITStatus(DMA1_Stream5, DMA_IT_TCIF6))
  159.         {
  160.                 printf("== %d dma rx\n",__LINE__);
  161.                 /* Clear DMA Stream Transfer Complete interrupt pending bit */
  162.                 DMA_ClearITPendingBit(DMA1_Stream5, DMA_IT_TCIF5);
  163.                 USART_DMACmd(USART2, USART_DMAReq_Rx, DISABLE);
  164.                 DMA_Cmd(DMA1_Stream5, DISABLE);
  165.                 usart2_rx_busy_flag = 0;
  166.         }
  167. }
  168. /*****************USART2  RX******************/
  169. void USART2_IRQHandler(void)
  170. {
  171.
  172.         unsigned char ch;
  173.         unsigned int temp;
  174.         int i;
  175.         unsigned short l;
  176.         /* USART in mode Sender   --------------------------------------------------*/
  177.         if(USART_GetITStatus(USART2, USART_IT_TXE) == SET)
  178.         {
  179.                 printf("== usart tx\n");
  180.                 USART_ClearITPendingBit(USART2, USART_IT_TXE);
  181.         }
  182.
  183.         /* USART in mode Receiver --------------------------------------------------*/
  184.         //if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET)
  185.         //{
  186.         //        USART_ClearITPendingBit(USART2, USART_IT_RXNE);
  187.         //        ch = USART_ReceiveData(USART2);
  188.         //        printf("-%c",ch);
  189.         //}
  190.         if(USART_GetITStatus(USART2, USART_IT_IDLE) != RESET) {
  191.                 USART2->SR;
  192.             USART2->DR; //清USART_IT_IDLE标志
  193.             DMA_Cmd(DMA1_Stream5,DISABLE);
  194.                 DMA_ClearFlag(DMA1_Stream5,DMA_FLAG_TCIF5);
  195.
  196.                 l = DMA_GetCurrDataCounter(DMA1_Stream5);
  197.                 printf("++ rx:%d\n",l);
  198.                 temp = 1024 - l;//DMA_GetCurrDataCounter(DMA1_Stream5);
  199.                 for (i = 0;i < temp;i++)
  200.                 {
  201.                          printf("%c",usart2_dma_rx[i]);
  202.                 }
  203.                 //设置传输数据长度
  204.                 DMA_SetCurrDataCounter(DMA1_Stream5,1024);
  205.             //打开DMA
  206.                 DMA_Cmd(DMA1_Stream5,ENABLE);
  207.         }
  208. }
