PT2262-IR is specially designed for infrared remote control applications and its output waveform<br />carries 38KHz frequency. To get the 38KHz carrier frequency at the data output, the oscillator<br />frequency must be 76KHz. A 440KΩ resistor connected between OSC1 and OSC2 pins of PT2262-IR<br />is recommended. Moreover, for a matching decoder frequency, 1MΩ resistor connected between the<br />OSC1 and OSC2 pins of PT2272 is also recommended<br />我用470和1M影响大不大?
