今日: 2|主题: 33110|帖子: 128803 收藏 (404)
如果在AHB的WRAP txn中未对齐,则从响应中期望得到什么
2018-9-9 12:50 0 260
PSEL = 0时APB3从机响应
2018-9-9 12:48 0 250
关于重试响应
2018-9-9 12:46 0 179
突发终止,在AHB上进行忙转移
2018-9-9 12:44 0 297
AHB从AHB3修订为AHB5,区别是?
2018-9-9 12:42 0 467
AXI3写数据与相同的AWID交织
2018-9-9 12:40 0 346
哈佛结构一直都不太清楚什么地方放code,什么地方放数据
2018-9-9 12:38 0 205
AXI-lite tlast signal missing and tready behavioral
2018-9-9 12:36 0 304
How to understand Exclusive
2018-9-9 12:34 0 254
Import SOC design in eclipse
2018-9-9 12:32 0 252
AHB protocol,what is meaning of single cycle bus master handover?
2018-9-9 12:30 0 464
Sampling on positive edge of clock of slave in AXI3
2018-9-9 12:28 0 401
Is there relation between the de-assertion of BVALID
2018-9-9 12:26 0 422
Additional Control Information Questions
2018-9-9 12:24 0 332
AMBA AXI reset?
2018-9-9 12:22 0 303
apb 2.0 continuous transfer
2018-9-9 12:20 0 343
Alignment Address Calculation in AHB
2018-9-9 12:18 0 268
Any advice on running 180nm ROM/RAM compilers on modern Linux?
2018-9-9 12:16 0 332
apb protocol checker (assertions)
2018-9-9 12:14 0 398
2018-9-9 12:12 0 521
2018-9-9 12:10 0 429
apb protocol checker (assertions)?
2018-9-9 12:08 0 291
AXI4 Burst Transactions
2018-9-9 12:06 0 444
Cycle Model Studio software
2018-9-9 12:04 0 232
What is Byte Invariance
2018-9-9 12:02 0 201
When Wrapping happens in AXI?
2018-9-9 12:00 0 186
Is during AXI unaligned transfer not all WDATA bits used?
2018-9-9 11:58 0 385
When should APB slave Sample address
2018-9-9 11:56 0 334
[ARM GICv3 - GIC Stream protocol]
2018-9-9 11:54 0 259
Is there any scenario where HWDATA
2018-9-9 11:52 0 190
What purpose does BURST feature in AHB serve?
2018-9-9 11:50 0 347
多核与单核的编译一样么?
2018-9-9 11:48 0 162
TEE对ArmV8 平台这样的多核环境的安全机制是怎样的?
2018-9-9 11:46 0 239
macOS Mojave 搭建 ARM 交叉编译环境
2018-9-9 11:44 0 613
Request for vendors: improve SPI/SSP
2018-9-9 11:42 0 371
error when compiling ClockDiv_XilinxS6.v on Nexys3
2018-9-9 11:40 0 302
How can I get IP-XACT descriptions of CMSDK components?
2018-9-9 11:38 0 269
AHB Slave HREADY
2018-9-9 11:36 0 171
AHB slave ·3
2018-9-9 11:34 0 555
AHB slave ·2
2018-9-9 11:32 0 520
下一页 »
快速发帖
还可输入 120 个字符
您需要登录后才可以发帖 登录 | 注册
