[产品供应] STC将推出15系列单片机(14.08.10收到最新STC15W4K32S4样片)
133695|489
yanwuxu 发表于 2011-5-24 13:20 | 显示全部楼层
STC说5月份开始送样的STC15F828EACS系列中的SOP20封装的不知道flash最大有没有60k?SOP28和SOP32封装的管脚用不了那么多^_^
a60885262 发表于 2011-5-24 14:36 | 显示全部楼层
181# autopccopy
程序太长;;贴不上啊。
 楼主| autopccopy 发表于 2011-5-24 22:01 | 显示全部楼层
181# autopccopy
程序太长;;贴不上啊。
粗略看了一下程序,你的使用中断来解码的,要注意两个问题供参考:
1 程序里使用的延时函数要注意1T MCU与12T的差别(速度差很多)。
2 目前的A版本的STC15F系列的外部中断是有BUG的,现在可以使用其他1T的10F/11F/12C5A 系列来试验,待B版本修正后才选用。现在建议使用上几楼贴的官方例程的解码方法。
 楼主| autopccopy 发表于 2011-5-24 22:03 | 显示全部楼层
新与旧:
INTEL P4004 & STC15F204EA 一起合照,科技进步的剪影。。。
转帖:
INTEL 4004专栏:http://www.intel.com/about/companyinfo/museum/exhibits/4004/index.htm
In 1969, Nippon Calculating Machine Corporation requested that Intel design 12 custom chips for its new Busicom 141-PF printing calculator. Instead of creating a dozen custom chips specifically for the calculator, Intel's engineers proposed a new design: a family of just four chips, including one that could be programmed for use in a variety of products.
The set of four chips was called the MCS-4. It included a central processing unit (CPU) chip—the 4004, a supporting read-only memory (ROM) chip for the custom applications programs, a random-access memory (RAM) chip for processing data, and a shift-register chip for the input/output (I/O) port. Intel delivered the four chips and Busicom went on to sell some 100,000 calculators.
Intel offered Busicom a lower price for the chips in return for securing the rights to the microprocessor design and the rights to market it for non-calculator applications, allowing the Intel 4004 microprocessor to be advertised in the November 15, 1971 issue of Electronic News. It's then that the Intel 4004 became the first general-purpose microprocessor on the market—a "building block" that engineers could purchase and then customize with software to perform different functions in a wide variety of electronic devices.
4004主题网站:http://www.4004.com
 楼主| autopccopy 发表于 2011-5-29 12:24 | 显示全部楼层
今天在试验STC15F204EA的模拟串口问题,使用官方数据表(STC15F204EA 20110319版PDF, 第8.2节 P187)的C例程:《8.2  利用定时器1实现模拟串口的测试程序----定时器1工作在16位自动重�模式》,C例程能编译成功,可惜串口无任何反应(本来应该循环发送0x55,0xaa)。用示波器也检查不到电平的变化。请问是什么原因呢?(确认单片机最小系统是正常的,使用的是STC15F204EA  1046批次和STC15L204EA 1034批次产品试验,均是这样的结果)。
后来也使用来了8.1节的定时器0的模式,也是不成功! :(
附测试例程,大家有机会也试试:
//演示STC15系列单片机利用定时器1实现模拟串口功能
//使用STC15F数据表110319版 8.2节例程(P187)
//调试版,未通过$$$
//11.05.29
#include "reg51.h"
#define BAUD  0xFE80                    // 9600bps @ 11.0592MHz
sfr AUXR=0x8E;
sbit RXB=P3^0;                          //define UART TX/RX port
sbit TXB=P3^1;
typedef bit BOOL;
typedef unsigned char BYTE;
typedef unsigned int WORD;
BYTE TBUF,RBUF;
BYTE TDAT,RDAT;
BYTE TCNT,RCNT;
BYTE TBIT,RBIT;
BOOL TING,RING;
BOOL TEND,REND;
void UART_SEND(BYTE dat);
BYTE t, r;
void main()
TMOD=0x00;                          //timer1 in 16-bit auto reload mode
AUXR=0x40;                          //timer1 working at 1T mode
TL1=BAUD;
TH1=BAUD>>8;                        //initial timer1 and set reload value
TR1=1;                              //tiemr1 start running
ET1=1;                              //enable timer1 interrupt
PT1=1;                              //improve timer1 interrupt priority
EA=1;                               //open global interrupt switch
//UART_INIT
TING=0;
RING=0;
TEND=1;
REND=0;
TCNT=0;
RCNT=0;
P0=0; //点亮指示LED
while(1)
  UART_SEND(0x55);
  UART_SEND(0xaa);
while(!TEND);
TEND=0;
TBUF=dat;
TING=1;
//Timer interrupt routine for UART
void tm1() interrupt 3 using 1
if(RING)
  if(--RCNT==0)
   RCNT=3;                 //reset send baudrate counter
   if(--RBIT==0)
    RBUF=RDAT;             //save the data to RBUF
    RING=0;                //stop receive
    REND=1;                //set receive completed flag
   else
    RDAT >>= 1;
    if(RXB) RDAT |= 0x80;  //shift RX data to RX buffer
else if(!RXB)
  RING=1;                  //set start receive flag
  RCNT=4;                  //initial receive baudrate counter
  RBIT=9;                  //initial receive bit number (8 data bits + 1 stop bit)
if(--TCNT==0)
  TCNT=3;                  //reset send baudrate counter
  if(TING)                 //judge whether sending
   if(TBIT==0)
    TXB=0;                 //send start bit
    TDAT=TBUF;             //load data from TBUF to TDAT
    TBIT=9;                //initial send bit number (8 data bits + 1 stop bit)
   else
    TDAT >>= 1;            //shift data to CY
    if(--TBIT==0)
     TXB=1;
     TING=0;               //stop send
     TEND=1;               //set send completed flag
    else
     TXB=CY;               //write CY to TX port
老鱼探戈 发表于 2011-5-31 20:22 | 显示全部楼层
直播...........
李国平+ 发表于 2011-6-6 11:15 | 显示全部楼层
原来15F104E类的芯片问题真不少,我是上个月刚打的样片,更新后的版本。
在电路板没来之前,用一块12C5604AD试验,没用到所有的特殊功能,只是基本51功能,用到二个定时器中断,定时器1用于按键检测与程序计时,时间10mS,定时器0用于不同占空比的波形输出0.1-10mS,程序只有几百个字节,IO只用二个,包含电源只用四个引脚。
因为东西太简单,程序写下来没经过修改在12C5604AD上完全没问题,前几天PCB板到了,接上15F104E,傻了,完全不是一码事,经过二天的修改调试,发现只有一个定时器正常工作,10mS定时正常,把二个定时器互换,还是只有10mS的正常,另一个定时器调到1mS,P3 .5取反,输出应该是500HZ,但实际上只有10HZ左右,定时模式用0或1都一样。
再换成11F01,结果还是不行,而在12C5604AD上,程序怎么改就能达到要求。
后打电话问朋友,朋友说F系列的是新产品,很多问题的,做产品千万别用,纠结了,这么一个简单的东西居然出了大问题。
李国平+ 发表于 2011-6-6 11:17 | 显示全部楼层
看了楼上的不成功例子,这个系列的中断还是没有解决,A版的外部中断问题改到B版的定时器中断了。
 楼主| autopccopy 发表于 2011-6-6 16:28 | 显示全部楼层
今天访问宏晶STC的官网 www.stcmuc.com ,竟然提示[您的网站已经到期,请联系您的服务商续费] :( 另一个域名 www.mcu-memory.com 还是正常的。因为很多时候我要上去DOWNLOAD 数据表。不过冒似最近一次更新的版本是 11.03.19...
 楼主| autopccopy 发表于 2011-6-6 17:10 | 显示全部楼层
在电路板没来之前,用一块12C5604AD试验,没用到所有的特殊功能,只是基本51功能,用到二个定时器中断,定时器1用于按键检测与程序计时,时 ...
我觉得这个可以联系它的技术支持,看看问题在哪里。不过建议出产品的话当然是要用实际芯片验证过才行,不能随便用其他芯片模拟。
我这个应该是A版本的,后来换了另一个版本的C程序IO模拟串口就正常了。
至于原因我也不清楚。。。
还有这位朋友回复“STC IO口的设置??”的帖子( https://bbs.21ic.com/icview-234204-1-1.html ) 的关于STC12C56xx 的IO设置寄存器PxM0, PxM1经实际验证,的确是写错了,应该对调(与STC12C5A, 15F的相同才对)。
STC12C56xx 110319及之前的PDF数据表关于IO设置寄存器PxM0, PxM1应对调
 楼主| autopccopy 发表于 2011-6-6 17:19 | 显示全部楼层
前天,买到一本《无线电》2011.06
其中P48页,有个用STC15L104做的小制作
作者朱棣 写得《DIY 莫尔斯码“随身听”》的DIY**
使用电池供电,所以使用低压低耗的L版本
当然我认为“随身听”应该更随身一点,用莫尔斯联系软件在PC上制作成MP3,下载到手机上,或者有些智能手机都有类似的应用(APP)下载的,如ANDROID的手机。不过还是对作者的DIY创意表示支持。其实以前就有人用PIC,AVR的8脚单片机制作诸如HAM 自动键和 小定时器等小制作了。。。YEAH~~~
 楼主| autopccopy 发表于 2011-6-10 19:37 | 显示全部楼层
今天下午 (17:30)www.****ducst 恢复正常访问!:lol
(11749)
 楼主| autopccopy 发表于 2011-6-18 21:29 | 显示全部楼层
主流51MCU的DIE比较:
(12356)
李国平+ 发表于 2011-6-27 15:12 | 显示全部楼层
刚打电话订二百片12F5604AD和15F102,12F5604AD要4.5元/片,只有15F104E,要1.7元/片。都比预想成本高了。
 楼主| autopccopy 发表于 2011-11-14 23:21 | 显示全部楼层
很久没来了。在虾坛得到一点消息:
新品:
1.3.1 STC15F2K60S2系列 2012年3月开始供货
1.3.9  STC15F204EA系列 A版本现已供货,B版本2012年4月 ~ 6月开始供货
1.3.11 STC15F104E系列 A版本现现已供货,B版本2012年3月开始供货
详见PDF, (最好用迅雷下载快些)
http://www.****ducst/datasheet/stc/STC-AD-PDF/STC15F2K60S2.pdf
本地上传了V111030中文版,分2卷压缩, 大小约共5.41M,需一起下载后解压。(已经去除PDF的密码,可以复制和粘贴文字和代码)
(17665)
 楼主| autopccopy 发表于 2011-11-14 23:23 | 显示全部楼层
1.1.STC15F2K60S2系列单片机简介(2012年3月开始供货)
STC15F2K60S2系列单片机是STC生产的单时钟/机器周期(1T)的单片机,是高速/高可靠
/低功耗/超强抗干扰的新一代805 单片机,采用STC第八代加密技术,加密性超强,指令代码
完全兼容传统8051但速度快8-12倍。内部集成高精度R/C时钟,±1%温飘,常温下温飘5‰,
5MHz~35MHz宽范围可设置,省掉昂贵的外部晶振。3路PWM/PCA,8路高速 10位A/D转
换(30万次/秒),针对电机控制,强干扰场合。
在 Keil C 开发环境中,选择 Intel 8052 编译,头文件包含<reg51.h>即可.
但是例如PDIP40的引脚与传统51不同,实现了40引脚得到最多的38IO(即去除电源和地),而且没有兼容品(STC还想专属,不让别家抄袭),要是缺货就很被动。当然,开发板学习时可使用转接板实现兼容。
喜欢的人会选用,不喜欢的还是不喜欢。在M0泛滥的情况下,大家各取所需吧。。。:)
下图是STC15F4K60S4的命名规则:
 楼主| autopccopy 发表于 2011-12-9 09:10 | 显示全部楼层
晕,STC的网页更新了(谢谢虾坛的网友提示)
其中15F的临时STCISP软件由V1.06 升级为V6.01了!(通用的STCISP 还是V4.88)
http://****ducst/datasheet/stc/STC-ISP-V6.00/stc-isp-15xx-v6.01.exe
同时增加了一个STC15F104ESW的数据表:
http://****ducst/datasheet/stc/STC-AD-PDF/STC15F104ESW.pdf
(18760)
 楼主| autopccopy 发表于 2011-12-12 08:41 | 显示全部楼层
记号:18888!在“1212”节的刚才给我等到了!:lol
触觉的爱 发表于 2011-12-12 12:44 | 显示全部楼层
新的工具不错,还整合的辅助工具,计算软件延时方便了
不清楚新旧批次的15F104是否都能正常下载。 4.88只能下载新批次的
 楼主| autopccopy 发表于 2011-12-15 11:35 | 显示全部楼层
对,新15F的STCISP已经升级为:V6.03的,集合了之前的辅助工具外,还有15F系列官方的头文件(//包含本头文件后,不用另外再包含"REG51.H"或者"REG52.H")!
http://www.****ducst/datasheet/stc/STC-ISP-V6.00/stc-isp-15xx-v6.03.exe
(btw: 其他15F104,204的数据表都更新了,大家可以看看)
(19068)
